其实,我们应该善用Minitab自带的help文件,我顺便查了一下,有些信息相信对你有用的.
Observed performance
The number of units in your process output that violate the specification limits. This statistic is based on combined data from all subgroups, so it represents what your customer experiences. The observed performance can be expressed in terms of nonconforming parts per million (PPM) or per hundred (percent
For example, a dairy farm fills 1 gallon milk cartons and you are analyzing the capability of the filling machine. The manager demands a maximum PPM defective of 1900. You produce the following table of observed performance:
Observed Performance
PPM < LSL
10000
PPM > USL
10000
PPM Total
20000
This process has an equal amount of output violating both specification limits, and the total number of nonconforming milk cartons per million is over ten times the goal. The process needs significant improvement.
Note
· Minitab calculates the observed performance identically for normal capability analysis, between/within capability analysis, and nonnormal capability analysis.
· If you do not specify a specification limit, Minitab reports a missing value (*) for the PPM exceeding that specification limit.
