1.Bachelor Degree, Electronic Specialty priority;
2.Have a good English with Oral, Read & Write .etc;
3.5 years experience or above, and working at EMS (PCBA & Semiconductor Encapsulation / Testing .etc) plant priority.
职位职责: 1.New supplier qualification base on Wong’s requirement;
2.Supplier annual audit and publish the checklist before actually audit;
3.To follow / tracking supplier’s improvement continuously after audit & CA;
4.To evaluate Supplier performance base on the annual audit result & material DPPM .etc;
5.Guide SQE technician to working, and ensure their job effectively;
6.To verify the suspect material for incoming material;
7.To communicate the quality issue with Supplier until it have been closed;
8.To purge abnormality material, and ensure it have been quarantined effectively;
9.Support IQC guy to check the material, for example: Raise the Incoming Quality Instruction to IQC guys .etc;
10.Be able to cooperate with related department (Buyer, PQE, Engineering.etc) effectively until material issue have been resolved, and push production line to improve if it isn’t really material quality issue;
